Allow more space for text tips
Antonio.A
Hi all!
In the "Synchronization setting - Filter" panel, the text tips in bottom position has a too little space in horizontal.
Enable full width would results in better legibility.
A similar situation occurs with "Synchronization setting - Synchronization" panel:
Thank you!
This may be an OS/language issue, seems to look fine on Windows for me.
I suppose there's a small gap on the filters page, but no where near what you are seeing.
Thanks for the report! Issues have been fixed for the next release:
1. Filter description: Added newline and disabled hard-coded line-wrap:
2. Sync description: Increased hard-coded line-wrap to 250 pixels:
