Hi all!
In "Synchronization settings" panel, variants "Mirror" and "Update" seems to allow only a movement from left to rightside.
It would be nice to allow user to alternatively choose the mirror/update direction right to left.
(Normally, "rightside" is considered to be the "correct" side).
Allow Mirror/Update right-to-left side
I think the choice for just left-to-right for a Mirror or Update sync prevents a lot of mistakes that may cause data-loss, and thus makes sense.
If you want to Mirror or Update sync your right-location to your left location, you can simply swap your left and right base location(s) using the circular two black-arrows icon mid above your left and right location(s).
