Not all files moved from temporary folder to recycle bin
muelli1975
today I discovered that FFS hanged for some seconds at the and of a synchronization process, when one folder from the temporary folder should have been moved to the recycle bin. After some seconds it finished without an error message, but the folder was neither in the recycle bin nor in the temporary folder was deleted. Some files that have been deleted or overwritten were in the recycle bin, but some were missing.
Best regards,
Christoph
muelli1975
Here are two screenshots of the behaviour, as you can see, the thunderbird folder (and many others) ist not in the recycle bin after sync:
This is standard Windows recycler behavior: If there is not enough space it will delete old recycled files first.
muelli1975
Thank you for your reply. I was wondering about this behaviour because it happended on a 1-TB-HD with 600 GB free space and a recycler size of 48 GB. But I did many operations, maybe the recycle bin was really full. Normally I clean it regalary.
However - best regards and thank you very much for your fantastic work!
Christoph
