Synchronize more than one drive
Is it possible to 'real time' synchronize two source drives with one target/backup drive?
Yes
You can synchronize your two source drives to a single destination drive, but if you Mirror-sync only to two different destination folders. If you Update-sync you could potentially sync to a single destination folder, but only safely if there is no overlap in file-names in your two source drives.
But preferably also then you use two different destination folders on your single destination drive.
Thank you, Plerry.You can synchronize your two source drives to a single destination drive, but if you Mirror-sync only to two different destination folders. If you Update-sync you could potentially sync to a single destination folder, but only safely if there is no overlap in file-names in your two source drives.
But preferably also then you use two different destination folders on your single destination drive. Plerry, 03 Sep 2024, 15:12
May I ask you to explain how the batch-file should be organized for the situation with two source drives and single destination drive containing two folders (for each source drive)? I tried to create one, but it did not work (probably I used incorrect syntaxis.)
Assuming source drives S: and T:, and destination drive D:
Create two folders on D:, e.g named BackupS adn BackupT
• If you want to sync the entire content of S: and T: to D: , define two left-right folder pairs in the FreeFileSync (FFS) GUI (using the "+" icon in front of you first left-right pair):
Pair 1: left S:\, right D:\BackupS
Pair 2: left T:\, right D:\BackupT
• If you only want to sync a specific folder on S: and T: to D: , define two left-right folder pairs in the FFS GUI :
Pair 1: left S:\[SourceFolderOnS], right D:\BackupS
Pair 2: left T:\[SourceFolderOnT], right D:\BackupT
Thank you, Plerry.Assuming source drives S: and T:, and destination drive D...Plerry, 05 Sep 2024, 06:34
Finally I figured it out.
