Disable SyncSettings UI when RealTime Sync runs
illahee
Newbie here.
I have not seen a way to disable the pop-up UI when a sync is being handled. I have searched a bit on the forum but must not have the correct search string figured out, but in my testing when a file change occurs and RealTime Sync sees this, the SyncSettings UI pops open. Can this be disabled ?
Thank you.
Save your sync as a .ffs_batch and make sure to check the box "Run minimized"
illahee
Thank you.
