Error syncing RealTimeSync with Google Drive
tt2693717
The gdrive protocol does not support directory monitoring
This error appears when I run RealTimeSync, if running manually it works, has anyone experienced this error?
Correct, you can't use RTS to monitor a GDrive location. Remove it from the RTS configuration
tt2693717
xCSxXenon,then RTS does not work in real time with GDRIVE
That is correct
