I have used v6.14 in portable mode on different computers having exactly the same OS configuration (Win 7 64 bits). It works correctly except on some computers: at start-up, the program is not responding during 30 to 40 seconds. After, I can process normally. No problem with previous versions. Any explanation?
Regards
Geo
V6.14 latency at startup
In fact, the program is checking for update at startup. No problem if I disable "Help > Check for new version > Check automatically once a week". If I click on "Check now", the program is not responding again during 30 to 40 seconds, then displays "Unable to connect to FreeFileSync.org" because my internet connection is done thru a protected proxy server. Maybe the same with a previous version: in fact, I had already disabled this feature in the past. But I cannot explain why the problem occurs on some computers only.
