on a Ubuntu 22.04 64 bits machine, I planed a cron job to backup my files on an external HDD with FreeFileSync (last version 13.7).
I created my cron job with Zeit. The cron job launch well the backup and I checked in FreeFileSync batch "Shutdown at the end", but...
There's no shutdown at the end, but this message :
Impossible d'arrêter le système. (can't stop system)
Failed to set wall message, ignoring: Interactive authentication required.
Failed to power off system via logind: Interactive authentication required.
Failed to start poweroff.target: Interactive authentication required.
See system logs and 'systemctl status poweroff.target' for details.
So, my question is : what is the problem ? where is the problem ? How to solve it ?
Thank you for your answer.
I tried this : launching manually the batch ; backup is OK and Shutdown at the end is OK.
No shutdown after cron automatic backup
Seems like it might tell you thereSee system logs and 'systemctl status poweroff.target' for details.
poweroff.target is in disabled status (as state and vendor preset)
But
Am I the only one with this problem ? Never happen before ?...
But
I already did these searches ; nothing better... always the same problem.
Under Linux Mint 22, after backup is run, a countdown window appears. When reaching 0, the computer does not shutdown and a window opens with the following lines :
Error starting "/home/francois/Documents/applis/freefilesync-14.0/Bin/FreeFileSync_x86_64".
Killed by signal 6
<Press a key>
The same cron task executed by hand shuts down the computer, no problem.
$ systemctl status poweroff.target
○ poweroff.target - System Power Off
Loaded: loaded (/usr/lib/systemd/system/poweroff.target; disabled; preset: disabled)
Active: inactive (dead)
Docs: man:systemd.special(7)
FreeFileSync ver 14.0
Killed by signal 6
<Press a key>
