Hi new to the Forum and looking to use FreeFile Sync with Windows Task Scheduler.
At the moment I have a couple of backups saved ready to automate.
If I manually run them, they fail unless I have started FFS with administrative privileges.
So if I schedule them to run under Task Scheduler, will I need to do anything special ?
The backups are from a laptop (Windows 7 Ultimate) USB external drive across a wireless network into a NAS server.
Thanks.
Schedule Backup with Windows Task Scheduler
Set it up just like any other task that you would run in task scheduler. Be sure to set it up as a user that has all the privileges that your sync routine needs. i.e. File and folder privileges.
Thanks, I'll give it a go.
