speedup of scanning possible if filenames not displayed?
optokl
On Win 7, the scanning of large folders (30 GB) takes minutes.
Is this: a) the scanning process, b) the file name display in the FFS window? It looks like each file name is displayed.
If b): make an option to switch it off? I might want to see the names, but not always. I am sure from my own software that all these accesses to display take extra time. Like changing ACL in Explorer: takes years and displays each file name, the same on the command line is much faster.
This is indeed the scanning process, FFS doesn't show each file name, which would be a trivial mistake to make.
optokl
This is indeed the scanning process, FFS doesn't show each file name, which would be a trivial mistake to make.Zenju
well, but it DOES show file names.
Maybe only every 10th or 100th or 1000th.
Still, would it be faster without?
optokl
to clarify, I am updating from a folder into an empty folder.
Even for 30 GB, it should not take 5 min to find out that the folder is empty and that everything needs to be updated.
The thing is, I cannot just click start and go away (the copying takes long, anyway). Even if I directly click update, I need to come back and confirm before the copying starts. Or can I change that behaviour?
You can simply run the sync as a .ffs_batch job and set error handling to "ignore".
Still, would it be faster without?optokl
No.
