Just installed it and created '1' event in windows task schedule, it starts ok every time i start windows, but when i check it on task manager i see '2' RealTimeSync.exe*32 processes and '2' RealtimeSync_x64.exe processes, and my icons bar shows 2 icons like if i'm runing 2 instances of the same program. Is that ok? I'm using w7 64bits
thank you
4 process and 2 icons
