Recursive RealTimeSync (with a bit of logic) CLI script
barneycarroll
RealTimeSync has been a boon for my current workflow, where I'm working with front-end (static files) in a huge Java spring application full of external maven dependencies. It takes about 20 minutes to build and deploy, but RealTimeSync has allowed me to keep parity of my front-end files between the version-controlled source checkout and locally deployed cache (I work on source, RealTimeSync checks for new and newer files there every 0 seconds and copies them to the server cache).
The problem comes when I do actually need to clean, rebuild and deploy: the server's cache is kept in a folder whose parent has a randomly generated name, so I need to find that folder, copy its name, open up RealTimeSync and paste in the new value, then restart.
What I'm wondering is whether I can use a RealTimeSync process to grab the new folder name, then start another RealTimeSync process with my previous settings, qualified by that new folder name to watch in, or whether I can run a simple bash script at the end of my build process and trigger the latter RealTimeSync process from there.
Any ideas?
The simplest solution is to use an environment macro instead of a fixed folder name. When the folders need to change, update the macro and restart from a script. Environment macros are supported for both FFS and RTS.
