Need to Restart to get New Files to Backup
TonyK1321
Hello - If I do a Synchronize Update on a folder the first time after I start FFS, it catches all files that need to be backed-up. But then, without closing FFS, I create a new file in that folder from another program, then do a Synchronize Update, it does not find the new file and does not do a backup. But if I close FFS then restart it, then do the Synchronize Update, then it catches that new file as it should. Is this a bug?
Thanks,
Tony
When you first open FFS, clicking synchronize also runs a comparison, since there are no queued actions. After that, it doesn't do this and acts on the remaining queued actions, which are none in this case. You have to run a comparison first on subsequent runs
TonyK1321
How about creating a setting to optionally do the comparison anytime you start a backup? Or, if not, then I will continue to quit the program then restart it every time.
I am not the dev, so I can't make that decision lol
My thoughts: If the queued actions is empty, AKA, everything is in-sync, clicking synchronize runs a comparison. Otherwise, if there are any actions still to be taken, then it just syncs based on the current queue.
Also begs the question, how often are you encountering this scenario and why?
TonyK1321
I need to run 2 or 3 different backups in sequence or FFS gets confused or the backup does not happen. I initially run a browser backup to get things into my E: backup folder from 2 browsers, then I do a backup from E: to F: that includes the Backup folder. If I combined them into 1 backup job, FFS does not do the sequence correctly since I'm updating a folder after it did its initial scan. So it is easier to run them as separate backup jobs. Also if I keep the program open, and create another file that falls within the E->F backup set, then I just have to remember to quit the program then restart it in order for FFS to find that new file to backup.
Ah, yes, the 2-stage A->B->C sync. I have had many of those because it is simply easier than adding more folder pairs and dealing with filters. I eventually did take the time to do this in my configuration so I wouldn't have to double-sync, but completely understand avoiding that work lol
Is it not quicker to just click the compare button than it is to close FFS and re-open?
TonyK1321
I'll try it, but with Win11 and a fast HDD and CPU, it takes no time to do.
TonyK1321
As an idea, it would be helpful if FFS ran some sort of analysis on the folders to be updated, and did them in an order that ensured all transfers happened in one run.
I'll try it, but with Win11 and a fast HDD and CPU, it takes no time to do. TonyK1321, 08 Dec 2024, 18:58
Clicking compare on an already open program is 100% guaranteed to be faster than closing and reopening the program. The comparison needs to run either way, reopening just takes an extra click
