Compare folder 1 with 2 and then copy a special amount of files to folder 3?
dirki-boy
Is it possible to compare e.g. folder 1 with 2 and then copy (e.g. all files existing in folder 1) a special amount of files to folder 3?
So, I want the only existing files (existing not in folder 2) in folder 1 copy to folder 3.
srjones67
I would say no. The object of FFS is to compare and sync a folder pair.
If you mean "limit on the number of files copied", then "no". If you mean "sync only certain categories", then "yes".
Sounds like you're looking for the "update" or a "custom" sync variant.
dirki-boy
Many thanks.
<<<If you mean "sync only certain categories", then "yes".
How could I do this?
<<<Sounds like you're looking for the "update" or a "custom" sync variant.
Hmm, obviously it seems to be like that.
Thanks again.
srjones67
Is it just me but if you're looking to compare 2 folders yet copy the files to a 3rd location you aren't looking to do a sync. And this is what FFS does a sync of 2 folder pairs.
dirki-boy
<<< And this is what FFS does a sync of 2 folder pairs.
Thanks for pointing this out.
