Question about RealTimeSync on Linux
Joel
Latest version of the app
OS: Kubuntu, fully updated
Where can I view the list of syncs that I set up in RealTimeSync?
When I open the app, it shows only the fields for entering new syncs.
When I open Task Scheduler, the window is blank.
However, RealTimeSync is still syncing, because I created a new text file to test it, and it synced.
Such a list doesn't exist
Joel
Okay, I'm just wondering why it doesn't show up in Task Scheduler? if I want to edit a task, how can I do that? There must be somewhere that the tasks are stored, otherwise they wouldn't be running.
When you created the RTS config, you saved it and chose where it was saved
