ESET NOD disable RealTimeSync
mr_joker
When RealTimeSync start sync data between 2 folders one in my computer and other on my laptop via router in my local lan eset disable communication of RealTimeSync and it stay in gray in system tray. After some minutes RealTimeSync enables and do sync but very often eset disable it again. If I disable Eset filtering network traffic then I have no problem and RealTimeSync work always and fine. I check Eset logs and found invalid packages which are problems for me.
Please help me.
