I know There is a built in feature to solve the NTFS/FAT UTC/Local time issue. But i do not want to use this feature because it needs to rewrite all the data and not once, but TWICE !!!!
I just would like to manage as explained in the Software Help file in the topic "Compare by file size only". Unfortunately, i could not locate the "GlobalSettings.xml" file in my Windows 7.
Could someone tell me where has gone this file ? (I plan to set up a tolerance of 24 Hours)
best regards and congratulation for this piece of software, only the above is missing to me !
How to set up a time lag allowance window to solve NTFS/FAT time difference
