New SFTP sync feature
ruslanme
Please, help me with the new feature - SFTP sync. I don't see any new button with SFTP label. When i try to write manually something like "sftp://10.95.5.247/data" or "sftp:root:password@10.95.5.247/data", FreeFileSync writes: "Cannot find the following folders: "C:\Program Files\FreeFileSync\sftp:\10.95.5.247\data". I am using FreeFileSync on Windows XP and on Mac OS X Yosemite - result is the same on both OS. I tried version 7.2 and even 7.3 beta (Build 07.07.2015). I don't know, how stupid can i get, what i'm doing wrong? I looked for the same problem in the viewforum.php?f=8, but did not find anything.
Please, teach me, how i can use this new (very useful) feature.
Thank you very much!
FFS supports SFTP only for Win Vista or later.
ruslanme
FFS supports SFTP only for Win Vista or later.Zenju
Thank you, i didn't know that. And it doesn't support SFTP for MAC OS X, am i right?
Yes, however for Linux and OS X there's an alternative SFTP solution using "sshfs" (described in the help file).
ruslanme
Yes, however for Linux and OS X there's an alternative SFTP solution using "sshfs" (described in the help file).Zenju
Thank you very much, i shall try it certainly. FFS is an excellent tool, so the good news that it supports cloud services.
