Error during compilation, missing file
vic2gre
I try to compile and install FreeFileSync 6.4 on fredora 20 64b and I have a problem.
I installed the last version of wxWidgets (3.0).
When I compile I have this error (sorry, in french) :
mkdir -p ../Obj/FFS_GCC_Make_Release/ffs/src/
g++ -pthread -std=c++11 -Wall -pipe -O3 -DNDEBUG -DWXINTL_NO_GETTEXT_MACRO -I../.. -I../../zenXml -include "zen/i18n.h" -include "zen/warn_static.h" -DZEN_LINUX `pkg-config --cflags gtk+-2.0` -I/home/victorien/Desktop/boost `/home/victorien/Desktop/wxWidgets/lib/release/bin/wx-config --cxxflags      --debug=no --static=yes` -c algorithm.cpp -o ../Obj/FFS_GCC_Make_Release/ffs/src/algorithm.o
/bin/sh: /home/victorien/Desktop/wxWidgets/lib/release/bin/wx-config: Aucun fichier ou dossier de ce type
In file included from algorithm.cpp:15:0:
../../wx+/image_resources.h:10:23: erreur fatale: wx/bitmap.h : Aucun fichier ou dossier de ce type
 #include <wx/bitmap.h>
compilation terminée.
make: *** [../Obj/FFS_GCC_Make_Release/ffs/src/algorithm.o] Erreur 1
I think it miss a link or somethink like that but I don't find. Is there someone who know this problem ?
mbcullen
For this include
to work, you need to specify an include path to the containing folder,
in this case <your wxWidgets>/include.
Try -I<your wxWidgets>/include
vic2gre
ok,
and how I do that ?modify the makefile ? spécific make command ? add somthing to PATH ?
Sorry for this question, I'm beginner in compilation
mbcullen
We both need help from the author, zenju.
I am trying to compile version 6.4 on Windows.
The source code is the same for Windows and Linux.
If you get past the problem cited above you will probably
run into the same problems I have with missing files
and folders (which were in version 6.1, but not 6.2, 6.3, 6.4).
