Hi there,
sorry for the linux newbie question, but are Linux 32 bit distros still Supported by FFS? since version 5.14, I've been unabble to find correposdent 32 bit files to download.
OBS: I've tried to run FFS 64 bit version in my ubuntu 13.04 32bit, but it does not start, what I guess is not exacly a surprise!
Does anyone know how do I solve this?
Thanks in advance, any help would be appreciated.
best regards to all
Linux 32 bit support
Hi again,
let me change my approach!
I guess, I should/may re-compile it to work in a 32 bit environment (Ubuntu). Considering that I am newbie in Linux usage but fairly reasonable user in general computing, may someone share his/her on experience saying how complex would it be to go in that way?
Of course just general tips would suffice, If community says the process is not that troublesome I would go to documentation on my own and hope share with other newbies (like me) the solution!
Thx all
Thx all
You can use a pre-compiled package supporting most Ubuntu versions:
https://launchpad.net/freefilesync
thx, much better in that way. :DYou can use a pre-compiled package supporting most Ubuntu versions:
https://launchpad.net/freefilesyncZenju
