How do use different synchronization settings for different batch operations
phastflyer
I would like to have some batch operations use an "Update" synchronization setting and some use a "Mirror" setting.
I can't seem to find a way to specify this.
I noticed that when I changed the settings to "Mirror" in the online dialog, the batch files I had already set up suddenly starting using "Mirror" so it appears to me that the "Synchronization Settings" in the online dialog are global to all freefilesync operations on the system.
I saw that there is some support for environment variable (%USERPROFILE%) was listed in the key features, but I couldn't find any way to use them.
I tried running "freefilesync" with command line arguments -h -? -help to see if there was a way to pass the synchronization settings via command line argument, but I didn't have any luck there either.
I am hoping that I am just not looking for the right thing.
Is there a way to have different synchronization settings for different batch jobs?
srjones67
You need to create separate batch configurations. Save the first and create a new one.
