LockDirectoriesDuringSync unclear
Hello: The help for FreeFileSync says that LockDirectoriesDuringSync "allows to operate FreeFileSync with an arbitrary number of users in a network out of the box.". Does "users" refer to users of FreeFileSync or does it refer to any users on the network doing anything at all? I don't understand specifically how LockDirectoriesDuringSync is intended to be used. Thank you.
I've revised the help file a little, is it more clear now?
Yes, thank you. When you say "against a common network folder", does "against" mean "writing" to a common network folder?I've revised the help file a little, is it more clear now?
https://freefilesync.org/manual.php?topic=expert-settingsZenju
And is it correct that LockDirectoriesDuringSync has nothing to do with Volume Shadow Copy?
Yes and yes.
