Please put this in a knoppix repository
chosenbygrace
Hi, I'd like to install this on knoppix however the program isn't listed, could you please put it in knoppix's various default repositories and let me know fototrick@gmail when you do? Also can you test this on a knoppix USB install please, because I find that back up programs for knoppix almost entirely do not show up in it's menu system, and often they don't even launch when using the Run app or the terminal, so please, make sure it works.
You should contact the maintainer of knoppix about adding FreeFileSync.
