RealTimeSync issues on one folder
pacojazz
Hi everybody,
I get a strange issue; i am currently sync two folder, all worked well since this morning. I can not more sync my two folders, and strangely i can do it on their subfolder. No permissions change on the Parent folder. FFSync can no more build it hidden ".sync.ffs_db" database, or scan change file. But if i target a subfolder, it is working !
Are There any limit on a folder which is not empty, or with a number of subfolder ?
Parent folder has a dozen de subfolder.
