I've tried a couple of versions of the commandline in RealTimeSync. I get the error:
>Invalid command line:
>File: C:\Program Files\FreeSyncFile\Freetimesync -
ah. Ok. I found my error.
Ok, now I have a new question. How do I delete this RealTimeSync process and replace it with one spelt properly?
I get Error Code 2: System cannot find file specified but the sync still works just fine.
Ok, I figured it out. It might be obvious to people a bit smarter than me but I'm only a lowly mechanical engineer...
Clicked on "Show hidden icons" and exited the job there.
Thanks. Closed.
Thanks. Closed.
