Empty Folders
jknapp82
Hi folks,
I have a Problem to "sync" deleted Folders. Files in the deleted folders are deleted correctly on "client-site", but the empty folders aren't deleted...
I guess because of the Filter Option "max 50 MB" ?
Any chance to get the (real) empty Folders deleted automatic on the "client" aswell?
I allways want to have the exactly same folder strukture on "both sides"...
Thanks a lot in advance!
Jochen
If the time span or time size filters are set, this implicitly excludes all directories from synchronization. This is done in order to avoid creating a lot of empty target folders when syncing, say, only files smaller than 50 MB to an empty target location.
The flip side is your scenario: Since all directories are implicitly excluded, they are not deleted on the target side, even when they are deleted on source.
