I have multiple folder pairs. Can I run them separately (one at a time) ?
hasitha-prabath
I setup 4 folder pairs in FreeFileSync. Can I run one backup job(One folder pair) at a time?
You can delete the folder pairs you don't need to sync, and not save this change to the config. But the most straight-foward approach is to save multiple sync configurations and on-demand merge them via mouse-selection (FFS also supports CTRL and SHIFT mouse selections on the config panel).
