Version: 5.21
Environment:
Windows XP Mode - virtual machine
Windows 7 - host machine
Problem:
I started to compare big folders (more than 20,000 items) on the C: drive of the virtual machine and USB flash drive. It worked fine until count about 12,000 items after program worked slowly and slow down virtual machine. CPU and HDD usage was low but virtual machine reaction time was long. Host works fine. I tried two different types of the USB flash - same story. When I used empty USB flash drive and did synchronize it worked fine.
I tried USB HDD and SDHC card in the buil-in card reader - in both cases compare worked fine.
v. 5.21 problem with USB flash drive and Windows XP Mode
