sync between xp and win8
none1000
hey all, im a newbee, so sorry in advance, but i have the following question:
when i try to compare folders between an xp and and win8 system, all files are different, as if sth in the file changes when copied on the other system. what is the problem here?
thanks a lot for any advice! none
none1000
does nobody have an idea? the thing is that i didnt change any file in both directories, i just copied die data from one system to the other. but freefilesync now says that all files are different. i dont understand why...
