Using FFS 5.22 10/1/13 64 bit build...
Just noticed that there is a discrepancy: when try to sync either of 2
folders that are on local and USB drives that are identical with 131 items
each to my network NAS drive folder with 4 items I get the Comparison
summary that the NAS folder is identical to the local folder. Same when I
Compare to the USB folder (which is identical to the local C folder).
Only thing I can think of is that recently when I was trying to sync an
Outlook folder with PST file, I got the warning msg that FFS unable to lock
the folder, and it just hung there, So I went into GlobalSettings.xml file
and changed the "LockDirectoriesDuringSync" as well as the Warn About
Locked directories parameters to "False" since I am not using multiple
instances of FFS.
Any thoughts here?
Thanks!
Sync not seeing differences
