I think The word "Multiple..." should be translated to "复合...".
This word is used to describe sync methon in "Create batch job" dialog.
It shows up when you created more than one folder pairs, and they had
different sync method.
(sometime you need to reload the batch job file to make "Multiple..." show up)
"Multiple..." 貌似翻译成 "复合" 之类比较好.
此词出现在 "创建批处理作业" 的 "同步" 组合框.
当批处理中有多个目录对, 且各目录对的同步方法不同时, "同步" 组合框中的提示为 "Multiple...".
(好像要保存并重新加载批处理作业后才出现 "Multiple...")
1 Simplified Chinese translation mistake
Sounds reasonable, changed it!
Thanks for the info, I'll fix this for the next release!
