FreeFileSync creates another copy in another disk
nicolafondo
Thank you so much for this great software!
When I update a file from my internal disc "W" to my usb disk "L" FreefileSync works fine but it creates the same folder (containig only the files that I have removed or created) in my internal disk "D". The sync "W" to "L" it's ok. I have just noticed that the wrong copy in the disk "D" happens when I click "Compare" after the syncronization.
Please, help, thanks.
Nicola
nicolafondo
Ok, it was my fault, I have created the "versioning" folder in the "D" Hard disk and of course it creates the folder every time I use FreeFileSync. My fault, it's all right, really sorry. Great software thank you again.
Nicola
