ffs silently failing - where are logs?
b_s
<br>
Trying to compare two directories, ffs starts the comparing then the compare progress disappears and the main window reappears. (Silently failing.)
Where are the log files kept so I can figure out why it's failing?
ffs 5.1.2
(It would be useful if the version / build were selectable on the about page, so they could be cut and pasted.)
\# uname -a
Linux mycomputer 3.2.0-56-generic-pae #86-Ubuntu SMP Wed Oct 23 17:51:27 UTC 2013 i686 i686 i386 GNU/Linux
\# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04.3 LTS
Release: 12.04
Codename: precise
\# ls ~/.FreeFileSync
./ ../ GlobalSettings.xml LastRun.ffs_gui
