Hi
On OSX 10.9.3 and FFS 6.5 (Build May 1 2014 - Unicode x64) I'm trying to sync 6GB of data. its pumping along at 115MB/s which is fantastic. Problem is if i turn of my monitor the transfer pauses. if i leave disk activity monitor open before turning off monitor, then leave monitor off for 10min, turn it back on i see the transfer resume.
this is on a Mac mini. rather then turning the monitor off I've also tried unplugging the HDMI (and then turning monitor off) but same result.
any ideas? i don't want to leave my monitor on for 6-7hours...
Transfer pauses without monitor
Found a workaround but not a fix.
set the power saving feature to turn the monitor off after 1 minute. wait for it to do that, then turn monitor off properly.
This seems to be the new OS X Mavericks feature "App Nap". I'll find a way to disable it during synchronization.
I made a few tests: the "App Nap" feature is disabled while FFS is syncing, so it must be something else that is slowing the disk when the monitor is turned off.Found a workaround but not a fix.
set the power saving feature to turn the monitor off after 1 minute. wait for it to do that, then turn monitor off properly.bmcneil3851
Is it possible that you are dealing with the following problem?
http://www.flynsarmy.com/2013/12/how-to-stop-osx-10-9-mavericks-from-sleeping-when-display-turns-off/
