"synchronise mirror": Error Code 2: Das System kann die angegebene Datei nicht finden. (The system can't find the file) (CopyFileEx)
volker987654321
FreeFileSync 6.5
I want to "synchronise mirror" from a NAS to an external harddrive.
The compare function works, but then at synchronise mirror no file is copied and I get this message: Error Code 2: Das System kann die angegebene Datei nicht finden. (The system can't find the file) (CopyFileEx)
How can I make the synchronise mirror function work?
volker987654321
works again after reboot!
Thank's
Can't delete this topic
