Bug: Changing Time/Date while Synchronizing
FYI -- The estimated time remaining completely breaks if you change the system time while the Synchronizing task is in progress. (Tested with v6.12 on Windows 7 SP1 x64)
Why would you want to change the system time while syncing? FFS anyway cannot handle changed system time beyond one hour for daylight saving. A MAJOR failing of the software for those of us who frequently change timezones.
Confirmed. This is due to FFS using the UTC system time for remaining time estimations. However, considering that this is non-trivial to solve portably and it's non-functional and should affect almost no users (UTC time should never change on a system, except for small clock inaccuracies!), this behavior will probably stay that way until further.
