Parsing the logs is made more difficult by the extra lines that occasionally appear for an individual entry in a file.
One line per entry will significantly ease the task.
Given that this would likely be a breaking change for existing code, perhaps it could be made a configurable option with the current format as the default.
Thanks,
Jeff Bowman
Fairbanks, Alaska
FEATURE REQUEST: One Line Per Log Entry
