Hi
It would be good to have the option that users do not have to open the full FreeFileSync GUI to resolve file change conflicts. Secondly, it is not desirable that when running minimized in batch mode, a user is not warned that a file conflict exists and the files remain out of sync.
Would it therefore be possible to implement:
- a simple pop-up (while running FreeFileSync minimized) asking the user what to do: keep one or both files (adding a suffix)
- an automatic resolution option to keep both versions without user interaction, by adding a suffix like OneDrive does in such case
Thanks for considering this feature request.
Cheers,
Wim Van Holder
Head of ICT PPW
KU Leuven Belgium
FEATURE REQUEST: Automatic file conflict resolution (as in OneDrive)
