add a simple option to support Google Drive !
hihihlo
I use FreeFileSync (FFS) to sync folders/files for Dropbox & Google Drive.
Google Drive always report can't sync file for sync.ffs_db, but Dropbox can sync it.
When I change sync.ffs_db' file attribute (remove hidden attribute),
Google Drive then can sync all sync.ffs_db files !
But FFS set hidden attribute every time when it finish sync work !
Could you please add a option to NOT auto hidden sync.ffs_db every time ?
It will be very helpful for use Google Drive,
Thank you very much,
Best Regards
