No portable path
blues12
External apps in the context menu only work when hardwired if the folder locations left and right are passed to FFS via command line.
Paths like
..\WinMerge\WinMergePortable.exe "%item_path%" etc.
only work when first starting up FFS, then browsing for locations. If the very same locations are passed via command line, the context menu will trigger an error unless hardwired with dirve letter instead of relative ..\..\ folder syntax.
