Forum
cinkowsky
Hi. How can I write something on "Open Discussion" about FreeFileSync?
I use Linux and ext4 filesystem and I think there should be added
"lost+found" folder to filters as default in FreeFileSync. Without it there
are errors while comparing files. Filters for windows filesystem, ntfs, are
added, e.g. /.recycle.bin/
Regards
*This is the Open Discussion section of the FreeFileSync forums.
So, you are spot-on.*
You are free to edit the include/exclude filter according to need or preference.
Your most recent settings are normally retained, or otherwise can be restored
(Left bottom corner: Configuration / <Last session>).
You might even (re)store different scenarios in/from different *.ffs_gui- or *.ffs_batch-files.
And there is "DefaultExclusionFilter":
[404, Invalid URL: https://sourceforge.net/p/freefilesync/feature-requests/381/]
