sync at shutdown
merovingi0
Hello, I set the sync at shutdown.
But if dimension of the file to sync are more gb, I have noticed that the
computer turns off before finish the synchronization.
It 's normal?
I have Win 7 Enterprise and FreeFileSync 5
2012-03-27 02:58:16 PDT
In case you're using "taskschd.msc" to schedule the sync, have a look at task
properties, tab "settings", "Stop the task if it runs longer than". This
should be set to some high value or unchecked.
merovingi0
hi, if i use taskschd.msc, the task don't start and show the error %1, and i
must to set the task on the gpedit.msc under the user config.
Did you try to setup taskschd.msc as described in the helpfile "schedula a
batch job"? There's no reason why this should not work.
merovingi0
yes,i want to start the sync at the shutdown, if i run the job manually work
fine, but if i scheduled it don't work :(
There are plenty of triggers available, something like "on logout" or "should
do. Also make sure to test the task manually in taskschd.msc (right-click
task, select "run")
merovingi0
ok, manually work fine, but if i set "on logout" don't start the task, instead
if i set the task under "gpedit.msc" the task start at the log out, but if the
sync are of more gb, after some time the pc shutdown.
