I have Free sync running between 2 sites. File synchronisation seems to be
good till now. Once in a while i get my wan link disconnected and free file
sync automatically creates a folder called FFS with the time and data and
automattically pulls all the data from the original folder to the new FFS
folder. Is there a way to prevent this from happening or set a timeout to wait
for a particular amount of time if breakage occurs between the 2 systems.
WAN interruption creates duplicate folders
FFS creates these temporary folders when deletion handling is set to
"recycler" and moves them to Windows recycler after sync. Chosing another
deletion strategy is the solution then.
