FFS Folder in Recycle Bin
asafdari
This is my first post to this forum,
I have few FFS batch jobs running with custom parameters;
Files/folders that exist on left side only - Copy from left to right
Files/folders that exist on right side only - Do Nothing
Files that exist on both sides, left one is newer - Copy from left to right
overwriting
Files that exist on both sides, right one is newer - Do nothing
Conflicts/files that cannot be categorized - Copy from left to right
overwriting
Error handling : ignore errors
Deletion handling : use recycle bin
The above batch script is running 6 day a week and similarly there is a mirror
script running for the same job on the 7th day of the week,
every day when the synchronization task finishes I have some folders in
recycle bin with name "FFS YYYY-MM-DD 000000" and I don’t know which files are
those and if I try to cut and paste the files from recycle bin it does not
work!
But when I compare my data I do not find anything missing everything seems to
be Ok! And the log files says synchronization completed successfully
Please let me know if I am missing any parameters in the scrip which is
causing these FFS folders in the recycle bin or my data is not getting synced
properly?
Thanks,
Ali
The "FFS YYYY-MM-DD 000000" contain all files that are to be deleted to
recycle bin during a sync session. So this is all fine.
asafdari
Thanks, for your feedback
