Making RTS/FFS instances more polite
dwig
I've got 8 instances of RTS running in the systray, occasionally spawning FFS
instances (sometimes up to 5 or 6 at once, more often 2-4). I've set things up
so they all run at "idle" priority (with a script that runs at startup time).
Even at this low priority, I often notice that the FFS jobs occasionally hog
the computer for a while (particularly when multiple instances are running at
once). As a workaround, I'll restore and pause them (one at a time, of course)
until it's convenient to "unleash" them again. I have two requests:
First, I suspect that some operation during the file scanning and copying
occasionally blocks, keeping other things from running. If this is the case,
it'd be nice if you could find a way to keep it from blocking, or maybe add a
"yield" in appropriate places.
Second, and less desirable, I'd like a way to manage the instances from a
script or app I'd write. Basically, I'd want to be able to do the equivalent
of Restore/Pause to each FFS instance with a single command to the script,
then Continue and Minimize with another. I'd probably write it in Python with
the win32 api, so I can probably deal with fairly low-level operations. (If
you can deal with the first request successfully, this wouldn't be needed.)
Before I forget, thanks again. I'm finding this app to be very useful; it
gives me a solid feeling that my files are properly backed up. I'm logging to
a folder, and I've added a bit to the startup script that zips up the logs
older than a couple of days to keep the number of files and disk space down.
Setting idle priority won't help because this has an impact on CPU consumption
only. FFS on the other hand is file I/O bound, consequently this setting won't
have much effect.
> maybe add a "yield" in appropriate places
Yield is only useful to keep a single process responsive. If the whole windows
session blocks this is due to hard disk I/O being at the limit. FFS itself
calls yield ever 100 ms and should be responsive all the time. (well almost,
except for first recycle bin access and initialization of VSS)
There indeed is a way to limit I/O: Beginning with Windows Vista it's possible
to categorize a process as "background/batch". However performance is severely
hurt with synchronization taking twice the time. So this definitively won't be
set as a default.
> manage the instances from a script or app I'd write.
I'm not sure it's worth the hustle to create an API for external use for such
a tiny feature. But what's already working is a simple "taskkill" on RTS
instances followed by a later restart.
