Drag & Drop _and_ conflict
cmg099
Thanks for the program. It provides some very useful functions, however there is one that I have not been able to solve.
I have lots of files that show a conflict. I cannot find a way to use "drag & drop" as you suggested in an earlier post, nor can I change the "conflict" symbol to a "copy from left to right" symbol, which is what I want to do (in this case). Is there an easy way to do this?
I have lots of files that show a conflict. I cannot find a way to use "drag & drop" as you suggested in an earlier post, nor can I change the "conflict" symbol to a "copy from left to right" symbol, which is what I want to do (in this case). Is there an easy way to do this?cmg099
Hi!
"Drag and drop" propably was the wrong term. What I meant was "Left-click, hold, relase" (LHR).
First ensure that you are in the "sync preview" mode (example: [404, Invalid URL: https://sourceforge.net/dbimage.php?id=217034])
Then you just set new directions in the middle grid using a single click for single rows or "LHR" for multiple rows.
Best regards, Zenju
