I have version 4.6 installed (was 4.6, nupgraded to 4.7, downgraded to see if reverting helped - it didn't) on my laptop, syncing with a server accessed via my work network. THe last couple of days, FFS gets part way through the comparison then crashes and dumps .dmp files all over the desktop (I have RealTimeSync set up to run but even with that deactivated and FFS run manually, even on only one folder, if crashes).
Please let me know what further information you need from me to help resolve this.
Version 4.6/4.7 crashes
You mean version 6.6 and 6.7? You can send the .dmp files to the email address in FFS's about dialog for analysis.
Yes, sorry, 6.6 and 6.7You mean version 6.6 and 6.7? You can send the .dmp files to the email address in FFS's about dialog for analysis.Zenju
Thanks - will send them now (ones that are left anyway, I've deleted lots).
