.deb package for Ubuntu
warakurna
Hej,
Finally, I managed to get FFS 2.2 working under Ubuntu. I think it would be useful to compile a .deb package which can be installed directly and integrates into the menu structure.
Beside that it is my program of choice when doing sync stuff...
Cheers,
Jan
I thought Linux guys are used to compile stuff :) Should be pretty easy following the compile instructions, or did you face some difficulties?
-Zenju
warakurna
Hej,
Cheers,
Janwarakurna
Actually I'm pretty new to linux (and ubuntu), so I'm not an advanced user. I will try when I'm able! :-) But if someone has compiled a deb package, it could be provided through sourceforge, or not?
Actually I'm pretty new to linux (and ubuntu), so I'm not an advanced user. I will try when I'm able! :-) But if someone has compiled a deb package, it could be provided through sourceforge, or not?warakurna
> not?
Sure... Currently I'm quite busy, so if someone sends me a .deb I'll gladly add it to the release.
-Zenju
yosu
Hi!
If you want that FreeFileSync can be installed in a good way into a Linux/Mac
system, you need change paths where FreeFileSync writes LastRun.ffs_gui and
GlobalSettings.xml files. Config files need go into $HOME/.freefilesync where
$HOME is an enviroment variable like %APPDATA% in Windows systems. I think
FreeFileSync needs read/write its configs from this directory that is writable
by the user. A portable FreeFileSync is good but if you want a .deb package,
you need change paths.
Also we need install program into /usr/bin/freefilesync, libraries into
/usr/lib, resources into /usr/shared/freefilesync to make a good installation.
Nowadays FreeFileSync reads all data from directory where is executing and it
is a problem if you want it to install as a normal application.
Greetings,
Yosu
Technically, It'd be no problem at all to have the same aproach for Linux like
for Windows: I.e. have a portable and an installer-based(deb.package) version
that reads writes from OS dependent directories as mentioned.
Currently there's "just" the portable version for Linux which should
suffice for most situations. However I totally lack the time of creating this
deb.package for Linux, so unless someone is interested into providing one,
this won't be in scope for now.
areymond
Hello
I have installed FreeFileSync on Linux Mint like this:
1° Zip-File unziped
2° From the new created folder: sudo mv FreeFileSync /usr/bin/
3° cd ..
4° sudo mv .// /usr/lib/
5° sudo ln -s /usr/bin/ /usr/lib/ /usr/lib//Resources.dat
6° sudo ln -s /usr/bin/ /usr/lib//Languages/
7° The FreeFileSync 'll be started with FreeFileSync (as root)
areymond
Is /usr/lib/ part of the PATH variable? If so, I could simplify steps 5 and 6
by first looking if its possible to load the resources without specifying a
path and only if it fails try to load it from the executable directory.
