Logfile Name
arrmo
Is there a way to determine the name of the log file used when running a batch
job? I ask because I'd like to send the log file in the body of an email, but
the filename changes each time.
Thanks!
Not directly. If it needn't be 100% accurate one could assemble the name from
current date and time before the sync-operation.
Or maybe the custom logfile directory can be used somehow?
Regards, Zenju
arrmo
I found a workaround - as part of the batch file to send an email I check for
the most recent file. Do you want the info for your readme?
Thanks!
Anonymous
For similar needs I have the bat-file set up like this (blat is the tool to
send e-mails):
<pre><code>
DEL /Q *.log
FreeFileSync.exe backup.ffs_batch
FOR %%i IN (*.log) DO blat ....
</code></pre>
Clever trick! ;) However using "move" instead of delete could be a bit less
"final".
sawdustagain
Thanks!arrmo
"as part of the batch file to send an email I check for
the most recent file"
I'd be interested to learn how you do that.
