I have a file in a speciifc location on my drive whcih I use regularly and
update but I also wish to have an exact copy of that file in another specific
location and do not want to keep copying and pasting the updated version
everytime a change is made. Is there some way I can use FFS to monitor the
file and everytime a change is made, to sync it to another location so both
copies are up to date?
Sync File after modification
I have just looked at RealTimeSync but it doesn;t seem to work for just a
specific file within a folder. I also have no idea how to set the command line
thing up?
thing up?
Yes, "RealtimeSync" has been created exactly to solve the problem you
describe. Have a look at the helpfile of v3.2 for a description how to setup.
> but it doesn;t seem to work for just a specific file
No problem, simply use the parent folder and use an include filter, so that
only your specific file is considered.
I'm really sorry, but i'm very confused?, Could you talk me thoguh the steps
to achieve this?
to achieve this?
Have you read the helpfile? What steps are not clear?
Everything really, Like you said I need to set up a filter. I found the filter
dialog in FFS but have no idea what to type in it. Sorry,
You can click on the help button to get some tipps how to specify a filter.
Generally: If C:\test\file.txt is the only file you want to include, you use
C:\test as to-be-synced folder and include "\file.txt", exclude nothing.
ok, I have set up my sync settings with the source and destination and set up
the include filter and that works as expected.
Now, I know what the put in the directories to watch field but what do I put
in the commandline box? I want it to watch the folder I specifiy and run that
specific syn settings file every time the file is altered but I also want this
to start automatically with windows so the entire thing should be a hands off
auto sync system
auto sync system
I have tried importing my exported FFS gui settings file into RealTimeSync but
it's only looking for a .ffs_real or .ffs_batch?
Yes, generally it only makes sense to start batch jobs when changes in the
monitored directories occured, therefore it is possible to also load
*.ffs_batch files with RTS.
You probably want to configure the *.ffs_batch file to run in silent mode, to
not show up when synchronization is active. Then load the *.ffs_batch file
with RealtimeSync to get a default configuration. Check, if it meets your
requirements.
To have RealtimeSync start with Windows create a *.cmd file containting
something like:
C:\FreeFileSync\RealtimeSync.exe c:\syncjob.ffs_real
requirements.
something like:
Ok, but what is a batch file? I only have a config file exported by FFS as
normal?
normal?
It's a sync-job that runs automatically without user-intervention. You can
create one via FFS's gui under menu->advanced->create batch job. Here you can
configure everything that is relevant for batch-synchronization.
The batch file I made runs perfectly but I wrote the batch file as this:
D:\Neil\Documents\Small Single Programs\FreeFileSync\64 Bit\RealtimeSync.exe
D:\Neil\Documents\Config and Plugins\FreeFileSync\keepass_to_dropbox.ffs_batch
saved as batch.bat and when run, it doesn;t open RTS in the system tray?
You should add "-characters as your paths contain spaces. Then retry.
Firstly Happy New Year and secondly it works perfectly now. Just have to add
it as a startup item!
Good to hear! :) And happy new year!!
